Home > General > 'Unbadged Autobiography' Question.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
My V5 doc states that my 2006 4.4 AJ-V8 Petrol FFRR is a 'Vogue SE'. However, thanks to a recent posted link, I have managed to get the build spec sheet and it is showing as an 'Unbadged Autobiography'
The vehicle is indeed unbadged, but is it really an AB? I don't see an AB badge under the bonnet - although I don't know where such a badge might be located.
I have done a search but didn't find a definitive answer.
Can anyone comment or shed any light on this please.
Post #492646 17th Oct 2018 1:06pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Pre-2009, Autobiography wasn’t a trim level, but a selection of special-order options (like paint and extra leather).
Post #492650 17th Oct 2018 2:43pm
Gyre8
Ah, OK. Thanks Trommel.
Maybe I'll turn it into a 'badged Autobiography'.
Post #492669 17th Oct 2018 4:51pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Pre 2009 the Autobiography was a special order model rather than being a standard specced lineup which it became in 2010. This meant those pre 2010 vehicles were pulled off the line and send to Special Vehicles to be customised - eg special paint, special trim, particular extras but as far as I know they were branded as Autobiography models and most had the tailgate Autobiograph badge, the Autobiography sill plates and I would have through all had the special vehicles sticker on the front passenger side air strut under the bonnet. There are lots of 'badged' autobiographies out there that are no such thing, just a badge bought from ebay and prior to 2004 there was a limited edition Autobiography (LE) showroom spec vehicle ( i have one of those) but they didn't go anywhere near the SV unit and don't have the badge on the strut. There are a few special Autobiography limited edition runs through out the L322 model years but they are all well documented. As I said there are a lot of normal spec vehicles out there masquerading as Autobiographies but sadly are nothing more than a superglued trim badge. You though, have the opposite - a potential hidden AB.
You haven't said where you got the build sheet from but I would ring up Landrover who will be able to confirm if it is a) an Autobiography and b) what was Autobiography'ed on it. It could have been an ordered AB vehicle destined for Special Vehicles which then had the order cancelled and it stayed on the line and became a normal specced vehicle. It could also have originally been destined for the LR press or executive fleet and specced up higher than normal spec and in order to get some options fitted into it it was badged that way in the factory even if it didn't go to SV.
Have fun. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #492701 17th Oct 2018 9:57pm
Gyre8
Thanks for the info nicksaab. I got the build sheet from here:
https://www.vindecoderz.com/EN/car-specifi...-equipment
As it happens I argued with the local LR dealer when I booked it in as, when I gave them the reg number, they said 'ah yes Tonga Green Autobiography'. I maintained it was a Vogue SE as shown on the V5.
Looks like I could be wrong.
Post #492704 17th Oct 2018 10:53pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
My paint colour is Zambezi 737 but this shows Paint Colours - Zermatt Silver [798] ? _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #492859 18th Oct 2018 9:23pm
Gyre8
Just dug out my V5C doc and it says Vogue SE A. Never noticed this before. Might the 'A' be the Autobiography designation?
Post #492941 19th Oct 2018 7:05pm
mjdronfield
Maybe. Can’t be A for automatic, as they were all automatic.
Must be someone else on here with another one to concur.....?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #492943 19th Oct 2018 7:22pm
nicksaab
In 2006 there were 276 new Vogue SE A's registered in the UK - that number climbed to 1,471 in 2007 and then around 900 in 2008 and so was a standard DVLA registered model designation with the A usually means Automatic. Landrover often registers models with the DVLA with an A or AUTO suffix and Autobiographies are AUTOB or AB suffix but there other combinations usually because the dealer didn't fill in the first registration form correctly.
My 2004 Autobiography LE is registered as an AUTOBIOG LE A and my 2012 Westminster is a WESTMINSTER TDV8 A
Hope that helps or confuses even further
Nick Current Fleet:-
Post #492952 19th Oct 2018 7:53pm
Gyre8
OK. Thanks nicksaab. Makes sense.
Post #492954 19th Oct 2018 8:08pm
