![]() | Home > eBay & Bargain Spots > Aluminium jacking pads. |
GI JIM Member Since: 23 Jan 2012 Location: Scotland Posts: 41 ![]() ![]() ![]() |
Going to pick up 2 sprinter jacks on sat from a breakers £40, he says he has lots???? |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
You'd be onto a winner if you combined the two...!
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
GI Jim, I'd be interested in a set please |
The part that Baltic Blue found on fleabay is back on again at 7.99 + 3.99pp don't think I could get the material for that |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3829 ![]() ![]() ![]() |
No they do not come pre-drilled., but are very easy to modify if you have access to a pillar drill and a 16mm bit.
I suspect it would be GI Jim, still be interested in one if you have the jack and the aluminium block, I had considered getting the ally block in multiples and doing a group buy -- I already do reversing bulbs as a group buy |
Me too! I've already got the ally pad but no jack and not really set up for that sort of drilling. 2010 4.4 TDV8 Vogue SE |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Interested in a finished product - not set up to do it myself. |
Are the jacking points the same on a L405 ?
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
I also wondered about the L405 jacking points although looking at the user manual it looks like they may be different.
Got the first 2 Jacks today. A bit of a shambles at the breaking yard but boss not in so I need to speak with him about exact numbers of Jacks he has.
Take care when you remove the horns off the top to NOT let the piston fall.
Cheers for that I most certainly will now |
