Home > Technical (L322) > Help with locating coolant leak.
tominator1982
United Kingdom 2003 Range Rover Vogue Td6 Baltic Blue
Hi everyone,
I have had a small coolant leak for a while. No obvious drops on the driveway but enough that gradual top ups have lead to the coolant level / mixture message to appearing every journey.
Just had a complete coolant change and message now gone but with the fresh coolant I've been smelling the leak and have now located a small drip and dry coolant on the side of the engine. The drip is located where point 6 on this diagram meets the engine.
I'm not technical, but any advice as to what item 6 is and what the issue could be would be much appreciated so that I'm armed with some info when I go to the garage.
Many thanks in advance,
Tom.
Post #493146 21st Oct 2018 7:18pm
holidaychicken
Not sure, if you look up that section on lrparts.ru you should be able to find it and if you click on it you will get a part number to google . ReaolOEM sute will give you the BMW part number if you search for X5 same year with M57 engine
Might help
Post #493182 21st Oct 2018 11:00pm
From RAVE
The radiator top hose is connected to a coolant outlet pipe which is bolted to the centre of the cylinder head. The elbow
also has a connection for the feed to the heater matrix via a flexible hose.
Post #493189 21st Oct 2018 11:49pm
tominator1982
Thanks both,
Again, please excuse my ignorance but in you opinion is that likely to be something sinister, or just something like a failed seal?
Many thanks,
Tom
Post #493225 22nd Oct 2018 11:46am
fisha
Unlikely sinister. More likely to be failed / degraded seals given the age, the rubber perishes over time, not helped by the cycling of heat from the engine.
Is the coolant definitely coming from the join between the engine block and that short outlet pipe (labelled B in Joe's pic), or is between the short pipe and where the hose ( labelled 5 in joe's pic ) connects on it. V8 or else ...
Post #493230 22nd Oct 2018 12:13pm
tominator1982
Hi and thanks,
I'm pretty sure its coming from between 'B' and the main engine block. Can't seem to find a definitive name or part no for 'part B'.
Regards,
Tom.
Post #493270 22nd Oct 2018 5:06pm
In RAVE, "B" is identified as the coolant elbow which connects to the hose - coolant outlet elbow to changeover valve
If the item bolted to the cylinder block is made of plastic, this could have developed a crack, or the connections to it are weeping .
Post #493271 22nd Oct 2018 5:19pm
tominator1982
Many thanks.
Just rubbed the joint with my finger and it's definitely weeping.
Looks like a trip to the garage... pain is, I've just had a coolant change!!!
I dread to think how many holidays I could have had with the money I've spent on this thing!!!!!!!!
Post #493272 22nd Oct 2018 5:25pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
tominator1982 - If you just had a coolant change, connect a hose to the radiator drain tap and put other end of hose in a collection bucket or such and save your expensive coolant to reuse it again.
Post #493549 25th Oct 2018 1:00pm
