![]() | Home > In Car Electronics (L322) > Central locking (Or not!) |
DarkWheel Member Since: 28 Sep 2015 Location: Manchester Posts: 31 ![]() ![]() ![]() |
Just a blatant bump to see if anyone can respond to the problem above? |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3249 ![]() ![]() ![]() |
Check for faults on iid if u can. Have the same model and year and my fault was heavy steering and rear pass door lock operating intermittently until it stopped all together. wouldn’t work on the central button nor key fob.
Thanks for the info - I'll check connections first!!
davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63 ![]() ![]() |
Try re-syncing the keys with the vehicle, to see if that make any difference |
Thanks David - I would've thought that if the key was out of sync - none of the locks would operate?
