![]() | Home > In Car Electronics (L322) > Android head unit advice. |
MattyB1983 Member Since: 05 Feb 2017 Location: Cambridge Posts: 81 ![]() ![]() ![]() |
Nobody have any ideas ???
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
Hi, i did this on my 2004 TD6, put the old head in glovebox, original leads do reach, just, then you need the front to back lead, once that is in, easy enough job, buy a unit for the BMW X5 if range rover not specified, i went with a EONON unit, fits like factory, there is a newer model out now than i have, physically the same, just slightly higher specced, does the lot, multiple usb, phone, sat nav, works with the DSP and SUB.Can get front and rear cameras too, more importantly. all the audio controls on steering wheel work via the i-bus. had mine in a while now, no probs, regards, Bob...
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
I've got one of the Erisin units www.erisin.com which I fitted two years ago, and bought it together with the front-to-to back extension lead. (My exact unit is now obsolete from their range)
Fantastic replies, thank you...
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 ![]() ![]() ![]() |
Hi Bobsin,
