Home > Wheels & Tyres > One rear tyre wearing on edge
pateire
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
Hi
I've a 2005 Td6 Vogue and even with proper tracking it always wears the rear left tyre about an inch or more in from the outside edge.
None of the other tyres do this at all. Tracking is always perfect for its annual test too.
Rear bushes and suspension is all good so I'm a bit puzzled why one tyre wears on the edge?
Anyone ever seen this before and any idea as to the cause and the solution? Right now I have swapped the 2 rear tyres just to even out the wear a bit.
Also even aside from that I do notice that the rears wear a lot quicker than the fronts. I would have thought the fronts would wear first due to steering.
Many thanks.
Pat
Post #493560 25th Oct 2018 3:23pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Have you checked the camber of the rear wheels (angle relative to vertical)?
I had 1 rear tyre wearing like that - caused by excessive camber on 1 wheel.
On our vehicle it was caused by very worn bushes, but it could also be caused by changing bushes & not optimising the camber afterwards or not installing the the cam bolts in the same position as before the bush change. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #493594 25th Oct 2018 7:22pm
nearlee
Wales
You say tracking.
Maybe a proper 4 wheel alignment is needed Remember:- amateurs built the ark
Proffesionals built the titanic
Post #493602 25th Oct 2018 8:19pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
As nearlee said, tracking is front wheels only and typically just toe. It may be that you mean 4 wheel alignmnet but f you don't its a totally different animal, laser alignment of all 4 wheels for toe, camber, caster.
I changed the rear bushes on my TD6 and it wore the outer edge in a matter of weeks before I could get the 4 wheel alignment done Rolling Eyes
Cheers,
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #493605 25th Oct 2018 8:24pm
pateire
Hi Pawl
Thanks for that. I did have bushes changed a good while back but it looks like one tyre was wearing even before I bought it a few years back. The guy that did the alignment is the best locally. Laser 4 wheel alignment and he's underneath with a screen. I couldn't say about cam bolts but would they be adjusted as part of the alignment? Thanks.
Post #493629 26th Oct 2018 8:27am
pateire
nearlee wrote:
You say tracking.
Hi Nearlee
Oops that's what I meant. 4 wheel alignment with lasers on each wheel.
It's a puzzle alright.
Post #493630 26th Oct 2018 8:29am
pateire
Cheers,
Paul.
Hi Paul
Thanks for that. Yeah I did mean 4 wheel alignment with lasers. The guy is underneath and has a screen. First he inputs make, model and size of alloys. I'm just wondering if the figures from LR are correct that they send out for castor, camber etc.
Mine isn't wearing that quickly but it is noticeable.
Thanks.
Post #493633 26th Oct 2018 8:34am
Pawl
If it has been checked with 4 wheel alignment. can you share the detail results for rear toe & camber? Paul,
Post #493634 26th Oct 2018 8:35am
pateire
Hi Pawl
I just found a report from the previous visit, but the same guy and I'd say the same values.
It does look though like the one tyre was wearing on the edge even before I bought it.
Not sure how much sense the 3 page report makes, but I am trying to attach it.
Many thanks.
Post #493646 26th Oct 2018 10:49am
