![]() | Home > Technical (L322) > blind spot retrofit |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 ![]() ![]() ![]() |
Hi all, does anyone know if the blind spot monitoring system can be retrofitted?
let me be clear here, i do not think that systems like this should make the driver complacent or to otherwise replace the drivers responsibility, surely these systems are there for the ones you don't see.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Mark
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I agree it would be a nice to have feature. But you could try moving your side mirrors out more. Someone pointed this out to me, that you don’t really need to see the side of your car in the mirror. ______________________________
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Was on my car when I bought it and doubt if I would miss it.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
Mine doesn't get activated by my caravan although the van is no wider than the car. However it is activated by roadside bushes on my not-so-wide lane. It has not activated in traffic that I know of but there's not much traffic in rural areas.
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102 ![]() ![]() ![]() |
Mark,
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
I have it and it's a good additional sentinal.
i could see it as being useful even if it never gets used in anger so to speak, and yes it irritates me that it hasn't got it, as does the lack of surround cameras, and powered rear seats!
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 ![]() ![]() ![]() |
Would it be worth looking first to see if the wires are fitted already as that might make up your mind if it's worth doing |
i am going to do just that i will have a look, does anyone know roughly where the sensors are for the rear? 2011 4.4 tdv8 autobiography black
The sensors could be in the side mirrors as the wiring schematic does not show any other sensors. The schematic only shows LEDs in the mirrors on a twisted pair, normally reserved for data bus usage.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
https://www.rangerovers.net/forum/6-range-...rofit.html
Thanks alan, that's more than useful |
