|  | Home > Technical (L322) > Rear reversing light casing |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102      | A little silicone sealant will be your friend  | ||
|  27th Oct 2018 2:47pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Yep.
|  27th Oct 2018 3:12pm |
| gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213      | Cheers guys, much appreciated!! | ||
|  27th Oct 2018 3:51pm |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434    | For info, the lens cover should have a tab at the bottom that slots into a hole, and it should be held at the top with a philips screw (bolt) into a plastic fixing.
|  27th Oct 2018 5:15pm |
| Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1102      | Joe, I think the OP had just the lens cap fall off, not the whole unit fall out  | ||
|  27th Oct 2018 6:01pm |
| Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245      | I had this same problem a few weeks back and can confirm the silicone does work. While they’re off it gives you a chance to give them a good clean inside before you stick them on | ||
|  28th Oct 2018 8:43am |
| Posting Rules
