Home > Maintenance & Mods (L322) > IID tool live values 4.4TDv8
Frans@Yamorna
South Africa 2012 Range Rover Vogue SE TDV8 Zambezi Silver
On the live value menu(tested) there is a option to see the EGT values for both turbos.I tried to read the values but it seems that there is only a default of 100 available.Has anybody had any luck reading EGT values?Am I doing something wrong? 2012 TDV8 Vogue SE 4.4
Post #494100 30th Oct 2018 6:38am
Baltic Blue
I am working on producing a list showing all the live values on the iid in a list giving typical readings and what they mean.
Here is a snapshot showing some typical readings of a DPF whilst it is in the middle of an Active Regen cycle.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #494103 30th Oct 2018 9:05am
Frans@Yamorna
Very interesting,thanks.Our cars in South Africa has no DPF.....maybe the EGT is link to the DPF or that without DPF the EGT can't be seen?
Interesting project you are busy with....will add value to the use of the IID tool!
Thanks 2012 TDV8 Vogue SE 4.4
Post #494106 30th Oct 2018 10:37am
