![]() | Home > Maintenance & Mods (L322) > New ball joints on Sunday, any tips? |
| Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479
good quality ball joint splitter. Had to beat the living Cr@p out of mine with a sledge hammer to get them to release 56 TDV8 Vogue SE
| mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63
don't forget the warm gloves and tea and big hammer |
| Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104
Hi let us know how you get on as I need to do mine
| stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276
Totally this. I’ve had jobs in the past where I’ve gone through 3 on the same job. And heat. |
| srpara Member Since: 03 Oct 2013 Location: moray Posts: 115
Loads of heat on ball joint on hub plus wd40 or similar and large hammer |
| mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766
They ended up staying in place, b@st@rd things. Replaced the arms but left the ball joints as they were still ok, and nigh on impossible to get out. |
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
same results as me!
oh, and replacing both the arms has actually cured all my noises from that corner even though i was trying to do the ball joint as well. however, the forky thing used to split the ball joints has ruined the boot on the ball joint in the process! |
sorry for the thread hijack but this was how my attempts to sort the ball joint developed...
interested to see if anyone replies to you Dexion, as i couldnt see how to shift them either. We contemplated heat but was worried about the other ball joint and the CV boot too... Took her for a 10 miles test yesterday and the annoying knock has gone, so very pleased with that |
I've been driving around with new arms and a hithertoo good ball joint which now has a knackered boot for 2 weeks now. Since I'm doing this all on the drive I'm losing enthusiasm since the weather has turned and i've still only done part of one corner!
You can just get new rubber dust covers if ball joint is still good |
Those strut bolts can be a bit of a pain... |
When I changed the bottom ball joint I used a flame resistant blanket ( like they use when plumbing in a sensitive area) to protect the CV boot
