![]() | Home > Technical (L322) > M62 Engine'd L322 |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 230 ![]() ![]() ![]() |
Oil leak directly behind the bumper if on the passenger side and I would be looking at the remote oil filter housing. |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 326 ![]() ![]() ![]() |
Brilliant thanks, is that a big job? Or not so bad? 2005 E60 M5
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
You have vanos solenoid seals which are probably an hour or two as quite fiddly and upper timing chain covers which are much more involved which I would guess at 5 hours maybe but somebody doing them every day would probably do them quicker.
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
In terms of suspension reset tools, I'd recommend just getting an IID tool, it'll do this job fine, but you'll likely need it at some point down the line anyway. Ptaroni has one for sale on this website for a good price. If that's too pricey for now, you can buy a EAS fault kicker off eBay for £70-80, just plug it into the OBD and it clears all those faults automatically in a second or two. I've got one you can have for £50 If you want it, been used twice before I got the IID. Obviously if there's an underlying issue, it's going to keep coming back |
Unnecessary quote removed
Have a root around the front of the engine, the upper timing chain covers go hard in a similar way to the cam covers and start to leak. |
Knightrider Member Since: 22 Mar 2014 Location: England Posts: 125 ![]() ![]() ![]() |
Get yourself the icarsoft LR v1.0 for about £100, it will reset all air suspension fault codes plus be able to diagnose all manner of other faults from gearbox to engine to airbag etc 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
i very nearly bought one of those, do you have one ? |
Yeh I do holiday chicken, highly recommended bit of kit. I got the icarsoft i930 first but returned it for this newer faster more features version. I got it for £95 from ukpartsdirect.com they were the cheapest I could find anywhere online 2004 Range Rover Vogue 4.4 v8 LPG, Java Black, 22' Hawke Alloys, Black Beast |
Thanks, well aware of an IID tool and have used one on an acquaintances SC. It was one of those things I intended to buy for mine but never actually needed it. I was rather hoping the circa £100 ish icarsoft jobs would have sufficed for resetting air suspension and basic fault code reading etc and it seems they can so I think I'll try one of those as middle ground between a kicker style tool and a full blow IID. To be honest I'm not sure I did the lock to lock procedure correctly. Could someone tell me exactly how that is supposed to be done? 2005 E60 M5
In all honesty, lock to lock almost entirely covers it. Go to full lock in one direction, hold for a couple of seconds and then the same on the opposite lock. It may clear some soft faults, but not a hard fault |
i must get one, i am always getting asked to look at people's range rovers but my allcomms only does up to 2005 and my faultmate is locked to my vin unless i pay £100 ish to swap it over and back again. ![]()
is is not that sensitive, mine normally clears straight away but with the engine running you just turn the steering all the way to to the left until it stops, all the way to the right and then back to the middle but mine normally clears as soon as i get to one side fully and start turning back. |
Cheers chaps, it has dawned on me that there may be some user error here. Again my inexperience with early ones here my be a factor.
Nope, mine doesn't trigger an inactive warning, the light just comes on |
