![]() | Home > Maintenance & Mods (L322) > flat battery |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
Car won't start after week away did the same after 2 weeks away in summer. Looking at batteries on Halfords web site it list HSB019 Yuassa whick is non AGM. Battery is currently LR genuine AGM! which is correct for 2011 4.4 TDV8 vogue or is either OK?
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3850 ![]() ![]() ![]() |
It needs to be an AGM battery, even though 2011 4.4 tdv8’s aren’t stop/start.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
my agm cost around £225 from JLR....more than other suppliers but circumstances dictated that i had to get one from them.. |
As Mr Bean says, prices vary widely, but so do guarantee periods.
Thanks for the replies. RAC on way to jump me off so I'm sorted for today at least. Will order a new AGM online I'll see if Advanced have one in they look the way to go.
If you look just in front of the battery, you will see you need a special 5 point torq bit to remove the charging unit.
Right finally got time and right weather to fit my new battery this morning. (Went for the Varta recomended by Baltic Blue).
i think its in the service menu.... |
Still not told mine and it seems OK.
Ah found it!
Paul,
It does just turn front side lights on there is also a Scandinavian setting which I think puts the headlights on. I’ll check the exact menu location when I get home. |
Car config, bcm body control, DRL standard. Change to active.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Mike Is this one the same physical size and CCA as standard? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
