![]() | Home > Maintenance & Mods (L322) > Wiring an Inverter |
Hi Carl,
Optima Yellow Top Leisure batteries are very good indeed |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
I'd do a check on reviews of the optima batteries. As I understand it they are only any advantage in a Landrover in so much as you can park upside down and not worry about acid leakage. Otherwise any good leisure battery will perform the same. I haven't had a personal experience but have seen the views of other Landrover 101 owners after using several of these when they were recommended on the 101 circuit and quite a few jumped onboard. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Optima are great, they last ages, but are very expensive. I took the view that I would rather replace my battery more frequently rather than pay out the extra. As I usually only keep a car for 2 or 3 years it's normally not an issue. |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
So, has anyone fitted an Optima as the main battery?. If so which one and what is the performance like?. Is it as claimed on the website?. |
No.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Is the chunky red cable fused? If not make sure place an inline fuse in the inverter cable very close to where tap into the red cable to avoid a burnt out Range Rover. Cheers Justin ![]() Gone - Range Rover Supercharged 2006 ![]() |
carl Member Since: 09 Feb 2011 Location: Norfolk Posts: 5 ![]() ![]() |
hey guys
if the inverter fuse is in the inverter case rather in the cable, theres a risk the cable could chafe on something causing an unprotected short.
The feed to the rear fuse box comes from the battery, via the front fuse box where it passes through a 100Amp fuse.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35729 ![]() ![]() |
just a headsup, asda have a 75 watt [150watt peak] plug in inverter reduced to £5 if its any help.. ... - .- -.
Worth noting that at 150Watts the maximum amp draw on that would only be 12.5A, the larger 300W inverters will only draw 25A so the wiring there will easily cope with that. The biggest inverter I can fins is 1000W, but at 83A the alternator wont be able to keep up with demand and you risk damage. ![]() |
Dan, is the ampage of the cable the total realistic loading without letting out the magic smoke or the spare loading assuming every other possible item running off the rear fuse box is switched on and doing its stuff |
The total allowable ampage on the circuit going by the fuse installed is 100amps - generally the cable will be rated higher than the fuse?
