|  | Home > Wheels & Tyres > improving Ride comfort L322 |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837      | I’m amazed that you think the ride comfort isn’t good.
|  2nd Nov 2018 11:10pm |
| quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 336      | 235/55/20 is a smaller diameter remember the profile, 55, is a percentage of the tread width, 235.
|  2nd Nov 2018 11:33pm |
| John1000 Member Since: 08 Apr 2018 Location: London Posts: 23    |
 Hi, ride is good but would like to improve it as much as I can. I am using the continentals crosscontact...car is a 2011 SC...thanks | ||
|  8th Nov 2018 7:00pm |
 yes, you are right. I should go for 255 55 r20, I do not think 275 55 r20 will work thanks | ||
|  8th Nov 2018 7:01pm |
| Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116    | How old are the existing tires? They degrade so slowly you don't realise how good a new set can feel until you slap them on. This might be as much a problem as tyre size. | ||
|  8th Nov 2018 7:22pm |
| Ticketyboo Too Member Since: 19 Mar 2015 Location: Kilkenny Posts: 38      | I have the Vogue SE 2010 TDV8 and my last two sets have been Michelin Latitude Sport 3 255/50 R20, okay not the SC, but the ride comfort has been excellent, grip superb esp in the wet and I get good wear (I rotate front-back every 3-5K miles), so much better than the Conti boots that were on when I got her.
|  9th Nov 2018 8:52am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878    | john, one option to improve comfort is to reduce the tyre pressures slightly by a couple of psi... | ||
|  9th Nov 2018 9:21am |
| John1000 Member Since: 08 Apr 2018 Location: London Posts: 23    | Hi Lester, they are from Nov 2016, they have 22,000 miles, thx | ||
|  9th Nov 2018 11:45am |
 thanks Stan, will try that | ||
|  9th Nov 2018 12:33pm |
| 160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 461      | I bought a set of 255/55 20 Michelin Diamris Sport for my previous L322.
|  10th Dec 2018 11:31am |
| Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545    | I think most people go for the L405 size which is 255 55 20 as they have a larger side wall hence improving comfort. | ||
|  10th Dec 2018 5:06pm |
| Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818    | There is absolutely nothing wrong with the ride comfort of an L322  running the correct tyres at the correct pressures    | ||
|  10th Dec 2018 9:37pm |
| Posting Rules
