![]() | Home > Technical (L405) > Engine bay cover. |
MJGH Member Since: 15 Jul 2018 Location: Essex Posts: 102 ![]() ![]() ![]() |
Just been out to look.
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 548 ![]() ![]() ![]() |
Thanks for looking. It was the bracket far left that made me question if something was amiss as well as the lip that runs behind the rubber seal.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
Yours (& mine) had the extra large capacity washer bottle fitted sir... The bracket would allow the blanking cover to be fitted if you didn't have the optional extra fitted |
Nice one, thanks for the explanation. |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Slightly confused, I thought the only option was an 'extra large additional water bottle', so can you also specify an extra large normal washer bottle aswell? On my car, I have 2 washer bottle filling points, one in the picture you show above, and one in the drivers side wing outside of the engine bay? Steve
Yes there are two filling points sir... If you look carefully at pic1 above you can just see the second filler in the top left corner of the pic... |
Ah yes, good point Craig, cheers |
