Home > Technical (L322) > interior clip part number
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
There are a few clips I cannot seem to find anywhere. I need the clip that holds the roof liner just behind the GPS antenna, and the push-on types that hold the D-pillar interior trim.
Are there any proper parts catalogs one can browse? like BMWs RealOEM? 2007 L322 3.6 TDV8 Stornoway
Post #494649 4th Nov 2018 10:49pm
a quick ebay search came up with this,
https://www.ebay.co.uk/itm/360-Pcs-Mixed-P...ctupt=true
Post #494650 4th Nov 2018 10:54pm
S.Hafsmo
Those are very nice and all, but contain none of the ones I need.
The one on the headliner is flat/wide and slides into a glued fastener in the headliner, an then into a metal recipient in the ceiling.
The D-pillar push-on two-piece clip.
And yes, I can see that my descriptions make no sense. 2007 L322 3.6 TDV8 Stornoway
Post #494651 4th Nov 2018 11:16pm
www.lrparts.ru
should have the clips on the catalogue on there. There is nothing that can't be fixed with a hammer😜😜
Post #494652 4th Nov 2018 11:17pm
S.Hafsmo
Thanks.
I found one that looks like the headliner clip I need. BritParts call it Headlining clamp plate.
According to them, this is however only to the 10-12 models. PN EDZ000020
Edit:
And the russian catalogue tells med its called HD1, and shows the same PN as above. I'll just try to get one of those.
It also seems that the D-pillar uses a more common clip than I thougt, it just looks different when both parts are together.
Pillar trim side,
Complete clip, EYC000340
Post #494666 5th Nov 2018 7:32am
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Phone Dan at Duckworth (site sponsor) he should be able to sort you out
Post #494682 5th Nov 2018 11:51am
thefisch6
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
S.Hafsmo wrote:
Thanks.
Edit:
Pillar trim side,
7 years late to the party, but just wanted to say thanks for posting this. I had been searching for this same part for nearly a week before I stumbled on this thread with the appropriate part number and name. Never would have found it without you.
Post #720001 18th Jun 2025 10:03pm
