![]() | Home > Maintenance & Mods (L322) > Fbh fuse |
| srpara Member Since: 03 Oct 2013 Location: moray Posts: 115
Fuse box passenger side
| Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282
Cheers mate
Yes that's the one |
Well pulled the fuse to reset the fbh still the same timed climate funs for a couple of minutes and turns off so it's looking like the fbh itself not sure what to do next I am reading about glow plugs or pcb , battery fault codes are saying unknown fault more investigating required
The fbh will only work when the temperature is below 4c ( I think that's it) any temperature higher and it will not run |
Have you had a read of the fbh write ups in wiki? |
Yes I've read them all confusing to me the timed climate should workbelow 16 degrees but it runs for only a couple of minutes then turns off and so far the fbh hasn't kicked in even at +1 so it's further investigation
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386
Don't forget that you also need at least a quarter of a tank of fuel and your battery voltage has to be good.
| Lester Burnham Member Since: 12 Sep 2018 Location: North Posts: 116
A quarter tank minimum, that could explain a lot, is that in the handbook? Never read that before but makes sense. |
| All times are GMT |
