Home > Technical (L322) > advice alternator
mark35gun
United Kingdom 2011 Range Rover Autobiography Black TDV8 Santorini Black
advice alternator
Hi all, bit of advice really, i had a non start issue yesterday with HDC inactive and charging fault, battery light on all the time so i have replaced the battery today, cleared all faults, the battery light has gone out when starting, but the iid tool is showing 11.2v so i double checked with a meter on the battery and that shows the same, does any one think that this will be the alternator?, bear in mind no battery light on and no faults showing do i need to re-set the battery? if so exactly how do you do this?, i don't want to book it in to get the alternator done, when only a reset is required, i have done a search for resetting the battery but have come up short in exactly how to do this Rolling Eyes
Can anyone offer any advice on the above? btw its a 4.4 tdv8 my2011 2011 4.4 tdv8 autobiography black
2006 td6 vogue buckingham blue
2000 p38 Holland&Holland gone, best car i ever had
1998 p38 vogue oslo blue gone
1998 50th edition v8 defender gone
1997 200 tdi defender red gone
1995 4.6 defender 90 green gone
Post #494891 7th Nov 2018 3:30pm
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Not sure what you mean by reset the battery but someone else might Very Happy ( only thing I know is to reset all computers etc is to disconnect both battery leads and tape them together for 20minutes)
If only getting 11 volts showing when engine running would point to alternator not putting out a charge ( check to make sure belt is good )
Post #494892 7th Nov 2018 4:14pm
Springer
United Kingdom 2003 Range Rover Vogue Td6 Galway Green
Hi should have 14v at the battery terminals with the engine running so looks like your alternator to me but check belts first
Peter
Post #494893 7th Nov 2018 4:21pm
mark35gun
belt is fine i can see it going round Very Happy 2011 4.4 tdv8 autobiography black
Post #494894 7th Nov 2018 4:30pm
srpara
That's a shame as would have been the cheap part to replace Sad
It points towards the alternator not putting out a charge (which will be expensive)
Post #494896 7th Nov 2018 4:35pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
+ 1 for an alternator issue. Should have 14v running. As suggested check the belt tension as the tensioner failing is a common issue. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #494897 7th Nov 2018 4:35pm
mark35gun
i think it is the alternator, its just throwing me because the battery light goes out on starting and there are no faults showing on the iid tool, so if you didn't check the voltages directly you wouldn't know 2011 4.4 tdv8 autobiography black
Post #494898 7th Nov 2018 4:36pm
srpara
Do you have a local auto electrician, they would be able to tell you for sure if it's the alternator or something else
Post #494899 7th Nov 2018 4:38pm
srpara
I've had an alternator give up on me but did not show a red ignition light on dash
Post #494900 7th Nov 2018 4:40pm
mark35gun
no worries on that one i can do it myself, as i said its throwing me because its acting as normal no faults and normal operation of the battery light, before i swapped the battery the battery light was on permanently, that seems to have cleared, and that's what is confusing me, hence the battery re-set question, as i know the charging system is not "as ordinary", smart charging i think its called although someone with greater knowledge may disagree 2011 4.4 tdv8 autobiography black
Post #494901 7th Nov 2018 4:46pm
Baltic Blue
If you do eventually need to change the battery, then the battery replacement reset is in the “Body control menu” section of your iid.
Post #494902 7th Nov 2018 4:49pm
mark35gun
ahhh thats the info i was looking for, prob is the Censored alternator then, i would still like to know how to reset the battery though?????, 2011 4.4 tdv8 autobiography black
Post #494903 7th Nov 2018 4:50pm
mark35gun
ok mike, but where? i can't see it in there, i can see a list of battery types but no "reset" button as such or am i being stupid?? Whistle 2011 4.4 tdv8 autobiography black
Post #494904 7th Nov 2018 4:53pm
Grofus
The charging circuit is designed for the AGM battery. I believe it is progressive but you should still have 14v with the engine running especially with a new battery fitted. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #494905 7th Nov 2018 4:55pm
mark35gun
yes so i understand, but only 11.5v Big Cry 2011 4.4 tdv8 autobiography black
Post #494907 7th Nov 2018 4:56pm
