![]() | Home > General > If you want a mk4 DVD sat nav might be worth a look. |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
The Mk4 Nav is very, very fussy about the media you use, good quality branded DVD+R seems to work best |
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Splash screen to cd was fine. Maps was problem.
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
ah - yes, the download is slow as he dosent have much bandwidth, so it crashed once or twice ...had that prob
Thanks. I'll ask him to try again. Once its downloaded correctly will it be as good as paying £30 of bimmernav etc or am i just being tight and should i be just buying one of their discs? |
also. if i put in the upated v32 splash screen is this the full update of v32 or just the splash screen. eg do i need to download v32 firmware 1st then change the splash screen 2nd?
It should be V32 firmware with the Land Rover splash screen but if your mk4 is already running v32 with the original BMW splash the system wont just change update splash screen. You would have to downgrade to V31 or older before upgrading to V32 with LR splash. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
So basically once i can get my maps burnt (or bought,worse case) with the cd my friends done with updated splash screen i should be ok provided my mk4 unit (that is sitting at postoffice) isn't already running v32.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
if you have problems with the dvd mapping, pm me and i can do you a backup copy at cost.. ... - .- -.
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
hi guys i hope someone can help ive just brought a hse and it has loads of extras but no nav and as with most of these stereos my lcd is playing up is there a way i can instal a sat nav system or maybe one of those aftermarket double din sat nav dvd cd players that are on fleebay...cheers guys sorry for the lack of knowledge its my first rr |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
aftermarket not stock. 2004 black Vogue TD6 |
I have my mk4 unit now but currently no disc. can i install, load the screen splash and re insert my current disc?
Nick, I would recommend making sure your mk4 actually works ok before trying to update the splash screen. |
That was the answer i was after thanks. Will the old cd/map (current) show in a new format (3d/slit screen/ colours etc) or will it look the same as before? |
It's the Nav software that controls the perspective/split screen view not the map disc so you will be fine |
