Home > Maintenance & Mods (L322) > Fuel lines quick connectors
doclees
United States 2004 Range Rover HSE 4.4 V8 Java Black
Anyone have a source for replacement quick connectors that connect to the fuel pump assembly? 2004.
Post #495087 9th Nov 2018 2:18pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Its been a while since I did my pump but think one of these will do..
https://www.aliexpress.com/item/Auto-Fuel-...d505310b5e 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #495137 10th Nov 2018 1:19am
doclees
Thanks. Yeah I'm getting the opinion that these are a universal size internally. That is that the 3/8 pipe fits all 3/8 quick connectors and all 5/16 fit all 5/16 connectors fit 5/16 pipes. I got a Dorman brand 5/16 to try tomorrow. I had this problem last time I pulled the pump. One was no problem but the other was a pain. Paranoid I might snap the pump assembly pipe. I know how it should come off but it won't.
Post #495138 10th Nov 2018 5:36am
doclees
Just to follow up. I was able to use the Dorman brand 5/16 quick connect and it seemed like a tight seal. On the down side upon removing, the assembly pipe snapped off. The age of the plastic and near freezing temps probably didn't help. In the future I would replace original with the Dorman or equivalent if needed. Sooooo I just order a complete new pump assembly for $95 delivered. Yeah it is probably cheap Chinese knockoff stuff but it has the lifetime warranty which I'll probably use one a year.
Post #495176 10th Nov 2018 7:01pm
