![]() | Home > Maintenance & Mods (L322) > Wire through firewall behind battery |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
There is, I ran a CB aerial coax through it. May I ask why you want the switched feed?, you might be able to use a voltage sensing relay if you want something to turn on when the car is running, a $3 drl controller direct to the battery would work. 2007 TDV8 VSE
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
Thanks Wayne . I suspect that with the cabin air intake removed I'd be able to better see behind the battery.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1522 ![]() ![]() |
Are you sure that what your trying to do isn't already done by the ECU anyway ? Modern throttle bodies naturally rest in a stuck shut position unless explicitely opened by a PWM signal feeding the motor that opens it. The whole idea being to stop just what you describe.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
A member lost an engine recently due to runaway:
The 4.4's butterfly is spring-loaded to the open position, requiring power to wind it closed, as is the 3.0 TDV6's in my son's D4.
No worries, my comments on closed throttle bodies were from a non-LR engine and I would have imagined that you'd want an engine to rest in a shut position ... but hey ! Good luck with the project. V8 or else ... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35818 ![]() ![]() |
if its any help i stuck my wire through the rubber grommet where the bonnet release cable goes [on left of engine bay as you look from the front] |
Thanks Stan. However I'm looking for the most direct route from the pcm to the fuse panel behind the passenger glove-box so will try behind the battery when I get a chance.
I abandoned the idea of running wires through to the fuse panel as being too much work, instead sourcing the ignition power from the IGN wire at the ecu connector. Permanent 12V was sourced via a fuse from the battery terminal's unused bolt and earth from the stud beside the battery.
