![]() | Home > Maintenance & Mods (L322) > TDV8 3.6 FFRR Oil Change - How to |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6430 ![]() ![]() |
Some additional information and images to add to andrewb's excellent tutorial on the oil change for a 3.6 TDV8
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Today I did my first oil/filter change on the 3.6 tdv8. It’s normally done by my local Indy at least for last 4 years since I’ve owned it.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2758 ![]() ![]() |
I never get under a vehicle with air suspension without axle stands or at least first disabling the air suspension by removing the 20A air suspension fuse (L322 MY07+, all D3/D4/RRS). The 20A fuse supplies the power to operate the valves so with this removed, at least the suspension system can't decide to lower. |
Good point. Another reason for ramps so the car is at least 300mm off the deck. ______________________________
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Hi,I've changed the oil on my 3.6 Tdv8 several times and am always surprised how little oil ( half a coffee mugs worth) drops out....so why is this,is the oil in there in a different compartment to the main sump and what exactly is the point of that rearmost sump plug? |
The rear-most plug drains the small turbo return drain line reservoir.. If not drained then sludge will build-up eventually blocking the turbo drain return lines causing oil to backup to the turbos and escaping via the turbo seals. |
Ah thanks for the explanation.Ive never bothered with using flushing oil first,is there any merit in doing so? |
I personally think oil flush is worth the expense (small in comparison with turbo replacement and engine rebuild) and effort.
So what's the oil flushing procedure please?
I always drop the oil every 6000 MLS,an hour of a job costing around £60-70,like you say small price to pay v turbos etc etc. |
The procedure is to add the flush treatment to the engine oil when an oil change is due and run the motor on a fast idle (I kept it at about 1500 rpm) for 30 minutes. Then a normal oil and filter change (drain the oil, replace the oil filter, refill with new oil). ______________________________
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Unnecessary quote removed
I do not think so. You will have to wait until the next oil change. . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
Oops |
