Home > Maintenance & Mods (L322) > dynamic indicators
dynamic indicators
a while back i posted this thread re dynamic/sequential indicators on the audis and how i liked them...
http://www.fullfatrr.com/forum/post451567.html#451567
it seems there are boxes available from china that can be wired up to normal indicators that allow this function..
https://www.ebay.co.uk/itm/2X-3-Step-Seque...2467227418
so, does anyone know whether the rear led lights on the 2010-2012 FF's can be adapted ?
Post #495318 12th Nov 2018 12:52pm
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
On the 322 the rear indicator only has one bulb, a standard tungsten filament......well mine is as I replaced one a few weeks ago.
As only one bulb there is nothing to “sequence”...... David
Please let me know if my comments upset you, I may wish to upset you again.
Post #495329 12th Nov 2018 1:37pm
hence my ref to 2010-2012 led indicators.....
there are 8 leds in the horizontal plain that can be sequenced...
Post #495336 12th Nov 2018 2:11pm
Boxbrownie
My bad......I thought all 322 had the single DI lamp, I guess if the LED pcb assembly can be physically rewired you might be able to sequence some how, but it’s only going to be limited to within the small round DI reflector, not sure it’ll be very visible as a sequential system as in the long thin type that Audi/BMW have. David
Post #495337 12th Nov 2018 2:16pm
if you fast forward to 6.12 on this video you will see the 2010-2012 indicators in action...
i think the way to find if this mod is possible is to find/get a broken tail light to experiment on..
Post #495340 12th Nov 2018 2:25pm
Stan, i think they are being worked on at present by Powerfuluk LTD...
May save you some messing about? Thumbs Up
Post #495348 12th Nov 2018 2:53pm
thank you craig...i wait in much anticipation... Wink
Post #495349 12th Nov 2018 3:03pm
i dont suppose you have any more info on this Craig?
Post #497221 1st Dec 2018 2:29pm
GGDR
Was looking at those too - Stan I picked up a 2011 tail light with a broken lens from another member.
If you want we can use as a test unit.
I've taken it apart, the LEDs come out, they are on a plastic flexible track. Kinda like a flexible circuit board.
Sending 12v into the light (off the car, just a straight 12v feed) lights up the LED solid, no flash.
So the flash comes down the line, a normal set up in that respect.
. Cheers, Greg
Post #497229 1st Dec 2018 4:39pm
i thought this would tickle your fancy greg Very Happy
so can the track be split into four bits so the light module could 'light' each in sequence...
the module in my previous post is a 3 way one but i have found a 4 way one on ebay...
Post #497231 1st Dec 2018 5:32pm
GGDR
I'll get it out, pull out the track and post a pic....
. Cheers, Greg
Post #497232 1st Dec 2018 5:42pm
nice one greg..
this is the 4 step module on ebay, strangely its location is in bulgaria....
Post #497233 1st Dec 2018 5:50pm
No more info I'm afraid Stan as i haven't been there for weeks and weeks! Alas been too busy!
If you need any bits to "mess about with" i have a box full of broken bits Thumbs Up
Post #497238 1st Dec 2018 6:40pm
GGDR
Close up of the ribbon cable:
Looking at the back of the light. There would be seven steps in vertical lines/rows:
Same pic with the rows labelled:
Lifting up an LED, the two dots you see in previous pic are either side of a single LED:
Here: three LEDs then a single, the one I just lifted
Now a few with the light off:
The LED is tiny tiny, super flat. Is that called a COB? It's next to my finger.
Finger off and it springs back into place:
So I'm not sure best way you would break up / into the ribbon cable.
Part of me thinks easier to wire up new LEDs and hot gun glue them into their sockets. You could remove and retain the whole ribbon and keep aside untouched.
Also the lens is bonded onto the black rear shell. That has to be prised off to get in and would of course have to be re-sealed.
Might have to watch a few YouTubes to get a handle on how to approach this....
Don't know, what do we think?
. Cheers, Greg
Post #497247 1st Dec 2018 8:07pm
When i made my last set of lights for my 322 i had to get two damaged lights and use the back of them then take two perfectly good lights and cut the back off slowly slowly slowly!!! Until i was left with four halves which i PU glued back together after assembling... Thumbs Up
Post #497248 1st Dec 2018 8:35pm
