![]() | Home > Maintenance & Mods (L322) > High Beam Mod |
| Druboo Member Since: 04 Jun 2017 Location: Wiltshire Posts: 12
2005
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
post pic of how they look in! |
| SamUK Member Since: 29 Jun 2017 Location: South Posts: 32
Not a main beam question but, what, if any, are the best replacement dip beam bulbs to buy? I know there xenon but there seems to be quite a choice on eBay?! Mine are useless, all I seem to get is the flicker as soon as you turn them on and then a useless blue/ice/white haze across the road, I much prefer conventional bulbs I must say.
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
The best ones are Osrams ones. The cheap ones will either flicker or like you say throw the light everywhere.
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2773
Has someone fitted 6000K HIDs? If so then 4300K are far better. |
Thanks guys, this RR is my first l322 so it's a bit of a learning curve with all these mod cons haha
holding you to it..... 2008 FFRR (sold) 2008 BMW M5 |
| Gbw321 Member Since: 05 Aug 2017 Location: Witham, essex Posts: 29
slightly off topic, but not much, i have just brought a 2003 L322 V8 and every time i start the car it says check front fog light, but they are working ok, would it be to the incorrect bulb being fitted? how would i check? |
Horse86.. here you go mate.. The photo doesnt do the justice.
Lens flare... Stand back and to more of an angle, you'll capture the beam of light better |
| Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182
Hi,I'm confused,which isn't difficult. My dec 2007 Tdv8 headlamps are xenon but someone mentions they have a shutter mechanism to enable main beam? Why do I have separate main beam lights then that appear a horrid yellow by comparison and seem feeble, presumably halogen h7's? I want rid,should I replace with led or bang in some 100w halogen.Also although I appear to have active swivelling headlamps and cornering lamp fitment in the headlamp unit but i never see any evidence of them working?? Thanks for any forthcoming advice. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Rapiscan.. I was exactly in the same situation and couldnt understand the point of the additional bulb for high beam when there is a shutter system on the main beam.
| AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464
Did they fit without modification?
Fitted without any modifications.. took 10 mins
