Home > Technical (L322) > alternator light
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
alternator light
battery light on but alternator tested and ok why is the light on on the dash,can anybody tell me what is wrong ,it is a td6.
Post #495718 16th Nov 2018 12:54pm
Bad connection on cable connecting alternator to Engine control module.
Fault logged on Engine control module.
Faulty Engine control module.
You really need to have the car connected to diagnostics to highlight the fault.
Post #495749 16th Nov 2018 6:25pm
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
When you say alternator was tested was it on or off the car?
I had similar problem my light was glowing and turned out to be a diode in the rectifier in the alternator. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Previous
59 MY2010 Range Rover Vogue L322 3.6 TDV8 Zermatt Silver
53 Range Rover Vogue L322 4.4 V8 Java Black
98 P38 Range Rover 2.5 DSE Champagne Gold
Post #495754 16th Nov 2018 7:32pm
cowman
the alternator was taken off and tested at a auto electric that is why we thought it was the alternator,i will scan it to see if anything comes up,thanks for the help
Post #495801 17th Nov 2018 1:19pm
cowman
well now wont start no ignition lights on the dash,and cant scan it no communication to scanner
Post #495821 17th Nov 2018 4:47pm
get a new battery on it... Thumbs Up
Post #495822 17th Nov 2018 4:48pm
cowman
it turns over fine just wont start and no ignition lights
Post #495868 18th Nov 2018 9:56am
