|  | Home > Technical (L405) > flashing shift (D) indicator, then knocks out of gear |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | Possibly a sticking selector mechanism.
|  18th Nov 2018 9:13am |
| 1959terry Member Since: 28 Apr 2014 Location: London Posts: 128      | Have you had an immobiliser fitted? 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
|  18th Nov 2018 10:32am |
| simplyash Member Since: 23 Feb 2018 Location: Leeds Posts: 13      | Hi, no immobiliser fitted, forgot to mention, the 1st time it happened, I restarted the car and the red triangle came on, restricted preformance, turned the car off for 10 minutes and and restarted worked fine, also called out the AA, who could not find a fault code. | ||
|  18th Nov 2018 10:39am |
| Goodfella Member Since: 04 Jun 2017 Location: Essex Posts: 77      |
 I had this exact same issue today, did you ever find out what it was? (I realise this is an old thread but worth a try..) | ||
|  14th Jun 2022 2:35pm |
| Goodfella Member Since: 04 Jun 2017 Location: Essex Posts: 77      | Car was running strange again today (lumpy I suppose is the best way to put it..) so into the garage I use it went.
|  15th Jun 2022 1:47pm |
| Posting Rules
