![]() | Home > Technical (L322) > Instrument gauges intermittent L322 '04 |
Richycsurfer Member Since: 18 Nov 2018 Location: Plymouth Posts: 44 ![]() ![]() ![]() |
Has nobody come across this? It seems to happen maybe once in ever 5 starts and takes stopping and leaving the car for a bit to forget it doesn't want to work. My alternator is putting out 14.2V so the battery is assumed ok but maybe it could do with a proper test? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35765 ![]() ![]() |
try a forum search ... |
It was my first move - nobody i can find seems to have the same things dying on the dash (just gauges) |
crowebeard Member Since: 19 Dec 2016 Location: Devon Posts: 93 ![]() ![]() ![]() |
While my dials are OK, the digital display used to suffer from a similar fault, it was either on or off and nothing I did made any difference to it and it wasn't just the standard pixel issue either. It's now permanently off.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
Do the general backlights work or do they flicker in time with the dials dying to zero. V8 or else ... |
No flashing it appears. It happened this morning working for around 5 seconds and then died. The speedo, temp and fuel all die instantly but the revs pulse while dropping.
So..gently pulsating fuel, revs and water but flaccid speedo.
Hmm interesting.
Thanks for the thoughts and reply. Not great news, then.
the self test stuff should flick the guages through their whole range of motion and back to zero. its a long time since i did mine.
Mark_L Member Since: 09 Nov 2019 Location: Essex Posts: 2 ![]() ![]() ![]() |
Hi,
Unfortunately I didn't yet... I've lived with it since however did have some advice to check the earth to the gauges, something which I havnt yet done
Thanks for the response.
EJL Member Since: 22 Dec 2015 Location: Belfast Posts: 1 ![]() ![]() ![]() |
Sorry to resurrect an old thread but did you ever get to the bottom of this? My fathers 2005 FFRR Vogue SE has recently started doing the exact same thing. |
