![]() | Home > Maintenance & Mods (L322) > EGR Blank TD6 Advice |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
1. Remove front engine cover
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
Thanks Joe. I was pretty comfortable with that bit (useful to know I'm not missing anything though!), but the bit I'm less sure about is the diamond shape blanking plate (pic attached). Assume this needs to go on the exhaust manifold, but it doesn't seem easily accessible. Is it an unnecessary step, or am I just missing something obvious
Hmmm, it is for one of two things:
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
The one you bought seems too much mucking around, you can get them which are simpler, just remove your exisiting one, fit this type in its place exactly how the old one was fitted. it looks O.E so inspectors won't know you have removed it.as pipes are still there, no blanking plates required like yours.'
Swipe Member Since: 31 Aug 2018 Location: Rustington, West Sussex Posts: 101 ![]() ![]() ![]() |
Done this to my TD6 a couple months ago very easy job no fault codes.
Fraynizzle Member Since: 27 Apr 2015 Location: Essex Posts: 111 ![]() ![]() ![]() |
Its Vacuum controlled so just plug the hose from the controller to the EGR valve.
