Home > Maintenance & Mods (L322) > How to fix a loose wing mirror
robanzac
New Zealand
Rob2529 wrote:
I had similar problems, that the mirrors would move under heavy braking, or acceleration. I just needed to tighten up the 4 screws from the first pic (even though there not there). If yours are tight then it must be deeper in the internals and andrews guide will be priceless! Thumbs Up
Same here.
If it isn't obvious, it should be noted that this flappy mirror problem can be fixed without removing the mirrors from the car.
Remove that plastic cover from the underside of the mirror and this will give access to those 4 screws.
They are T15 Tork.
As the original photos from this post are now gone I have added a couple of my own.
 Rob
Post #466914 2nd Feb 2018 5:38am
Wurzel
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
Yes any chance of more photos? The mirrors are quite different on my '08 to those above - there is a cover on the bottom though it's not immediately obvious how it's removed. Am wondering if the loose mirror problem can still be fixed without removing the door card etc?
Post #495881 18th Nov 2018 12:27pm
robanzac
New Zealand
Sorry, I have no more photos.
I would try to get that underside cover off first though before venturing in anywhere else.
Probably like all things on these cars it is only after you get it off does it become obvious how it is done.
My covers have a slight indent at one end that allows a small screw driver to be used to pry and squeeze. From memory it is actually the squeezing action that really gets the thing un-hooked Rob
Post #495927 18th Nov 2018 7:41pm
Wurzel
Thanks Rob.
I went ahead and removed the door card to get the mirror off and into the workshop. The cover below the hinge is an absolute pain to get off, but eventually can be removed with a combination of brute force and leverage. I'm fairly sure it's not supposed to be removed, as doing so reveals nothing but the bottom of the hinge mechanism:
Unfortunately on this model there are no screws and no way of tightening anything, removing the mirror glass and going in that way also doesn't help, as the plastic is riveted in preventing further access. It also turns out the mirror glass tabs get brittle after 10 yrs; so I'll be ordering a new glass as well!
The looseness appears to be above this mechanism in amongst the motor somewhere, will have to live with it for now.
Post #495930 18th Nov 2018 8:08pm
robanzac
New Zealand
They fight all the way don't they.
So anyway the thing to note here for anyone else is that my (potential) fix is only applicable for early models (up to VIN 4A999999) and thereafter (5A000001 to 9A999999) the mirrors changed and the fix is probably more involved.
(By the way I am just getting these VIN numbers from the Microcat at http://cat.lrparts.ru/ under Range Rover 2002-2009 >Body and Paint) Rob
Post #495940 18th Nov 2018 8:44pm
Wurzel
I'm ashamed to admit that before taking the whole thing to bits as noted in my previous post, I perhaps should have just retracted and extended them first.
Having now done so, all flappiness has gone.....
Embarassed Embarassed Whistle
I hope of benefit to others!
Post #500660 5th Jan 2019 6:01pm
Roberto
Yugoslavia 2003 Range Rover Vogue Td6 Zermatt Silver
Hi
I am new to this forum
I noticed that photo are not available, can you refresh them?
Thank You
Roberto
Post #523276 30th Jul 2019 9:50am
original pictures are not available... ... - .- -.
Post #523279 30th Jul 2019 10:15am
Big Tings
2004 Range Rover Vogue Td6 Bonatti Grey
Does anyone carry out this repair for others or is there anyone that can be recommended as such ?
Post #524829 14th Aug 2019 7:35pm
JohnK
United Kingdom 2003 Range Rover HSE Td6 Zambezi Silver
Just done mine so adding some photos of the mirrors and door cards that others may find useful.
Post #553874 14th May 2020 4:06pm
JohnK
The reason mine were loose was a worn lug, I built it back up with epoxy and filed back to the correct size / shape.
You can see it in the center of the picture, it should be all black but it has worn quite a step. that 2-3mm there translated to about 15mm movement at the outside edge.
There is now no movement in it, my only concern is if the epoxy is upto the job, but it was all I had to hand.
Post #553876 14th May 2020 4:12pm
