![]() | Home > In Car Electronics (L405) > Auxillary Power Socket (main one) fuse / Troubleshooting |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 ![]() ![]() ![]() |
Could it possibly be fuse number 63 in the passenger compartment fuse box which is listed as Front cigar lighter (20 amps Yellow)? |
abuss Member Since: 04 Dec 2013 Location: Ruenenberg Posts: 56 ![]() ![]() ![]() |
good luck with changing fuses.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Well done Dan, I simply did not see it on the list before.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
Might artery forceps help with access? Available from fishing tackle shops as well as medical suppliers (used for removing hooks without handling fish). Only Range Rovers since 1988 |
Long nose pliers work ok. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Did you get anywhere with this? I found fuse number 63 (pig t get to) and it was indeed blown, I changed it!!!!!! Murder of a job! But it still does not work?
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 222 ![]() ![]() ![]() |
I got my new (ish) L405 home yesterday and noticed the same problem. Fuse 63 was blown. My fondness for my new car was tempered slightly by the inaccessibility of the fuses behind the glove box mentioned earlier. Fuse 63 is the most cunningly obscured of all of them. Managed in the end to get the fuse out of slot 63 by first removing the relay to its right. Replaced the fuse with much swearing and now have two spare fuses floating about in the internals somewhere after dropping them. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
Today I had to change fuse 63....after an hour I was going to pop down to my local maternity unit and see if the on call gynaecologist could spare a few minutes. Bloody ell ! Trim off under glovebox, kick panel off ( once I'd removed the bonnet opening handle ) and large electrical plug disconnected...all just to change one fuse. Hang your heads in shame LR engineers/ designers. |
Quarryman Member Since: 20 Feb 2022 Location: Wiltshire Posts: 11 ![]() ![]() ![]() |
Further to my frustration I have found there are several fuses for the various power outlets
