![]() | Home > Maintenance & Mods (L322) > Brake pipe repair now completed |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1395 ![]() ![]() |
Who are you usung henda
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Just make sure he takes the covers off on the front to rear pipes (up in the channel) they will be all rotted to hell .
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Yes joe that's what he said which is why I thought he seems to know what he's on about
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3927 ![]() ![]() ![]() |
Yes don't mess about, I had a high speed trip back from Scotland with 4 blokes and 4 bikes when I got home I noticed a puddle on the driveway - yes you guessed it - Brake Fluid. Without warning a pipe had burst and I had to drive it to a nearby Indy to get it fixed. As any new fluid (and I used plenty) just |
Lucky
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I replaced both front to rear lines myself. They are a bit tricky to do but they come from Land Rover pre-shaped at around £12 each. The nearside is easy to do but the offside is L shaped to run across the rear of the car. That’s the tricky one! |
Do they both run down the near side under the plastic cover and are the brakepipies from LR a stock item or do they need ordered |
Yes that’s correct. Remove the plastic covers and you’ll see them. They corrode on the exposed sections.
FF is in the garage for brake pipes and the guy just rang saying the rear flexi-pipe on the near side has gone as well told me to pop down and take a look so he seems an ok guy
So the FF went in for a leaking front to rear brake pipe and as I expected I've had both front to rear pipes and both rear flexi pipes needed doing
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I'd say that was a very good price |
