Home > Maintenance & Mods (L322) > ABS Modulator Piping
Sabbsy
I could do with replacing the ABS Modulator Piping but I don't know the part numbers, does anyone know? basically the six pipes you unscrew from the modulator.
Post #496465 24th Nov 2018 7:46am
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Can you clarify a bit? Do you mean the brake pipes?
Post #496467 24th Nov 2018 9:23am
Sabbsy
Yes the brake pipes connected to the ABS mod, there are six of them.
Post #496470 24th Nov 2018 9:39am
www.lrparts.ru There is nothing that can't be fixed with a hammer😜😜
Post #496472 24th Nov 2018 9:42am
Sabbsy
Post #496473 24th Nov 2018 9:43am
Dolphinboy
Shocked Sad
Post #496518 24th Nov 2018 9:59pm
rjff
Can you let us know what happened and, when fixed what you did to repair?7
Sorry for the problem. Cheers
Richard
Gap IIDBT
Post #496657 26th Nov 2018 12:08pm
Looks like "you could do" with replacing the ABS modulator / plug connector and cabling Shocked What happened there...?
Pipework actually doesn't look too bad (fortunately most of it is inside the engine bay) it will only be the other end of these pipes running to the front wheels and the rear that may be rusting away.... .
Post #496659 26th Nov 2018 1:24pm
