Home > Technical (L322) > TD6 Fuel problem??
HARDRANGE ANDY
Australia 2004 Range Rover HSE Td6 Zermatt Silver
TD6 Fuel problem??
Hi from australia. I co-own a company called hardrange, which builds and sells aftermarket accessories for rangies, mainly the p38.
I'm trying to fix an engine problem with my TD6. I purchaced it with an engine problem and not running. It was running fine for the previous owner, then it ran rough and stalled in traffic. He took it to the closest dealer who promptly changed the fuel pump, but this didnt fix the problem. The dealer then sudgested the turbo, but i find this hard to believe as it doesnt even fire up. I plugged in my snapon scanner today and checked the codes. Engine ecu low voltage, and somthing about glow plugs.
The battery was flat (12v) so i charged it and cleared the faults. They didnt return. I removed the air inlet and held a petrol fume rag infront (works similar to aerostart on a diesel) and it fires but you can tell that their is no fuel going in or not enough to start. I checked the fuel preasure phisically (puled the hose off after the filter) and electrically - scanner said 3.6 bar). I unplugged N0 1 injector and this logged a code, so they are all still talking. I checked the glow plug relay - putting out 12v, so thats ok.
I have checked the condition of the fuel by purging with fresh.
I also removed all the return pipes from each injector and inserted a piece of tube over the fittings. No fuel seems to be coming out of the injector returns at all when the engine is cranking over at all. There is fuel preassure however coming out of the return pipe at the front which all the returnd feed into??? I thought that this pipe was meant to flow back to the tank?
any sugestions????
Andy hardrange.com
Post #47051 23rd Jan 2011 6:10am
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Re: TD6 Fuel problem??
any sugestions????
Andy
This has me a little confused, have you tried each injector with a leak off test.. i.e. 6 pipes in to 6 vessles?
I have had similar symptoms with one injector failing which didn't throw up any engine management lights. I don't know if it threw up any codes as we were in Italy then France when it finally died (Couldn't get the parts in Italy long enough to hang around). Im may case it was injector number 4 (numer 1 being at the front of the block)
There are two pumps, Low pressure and high. Sound like your high pressure is ok from your results. Do a search on Low pressure pump, its been discussed recently but I've just finished a night shift here in blighty so I can recall the finer detail. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #47052 23rd Jan 2011 8:28am
i see you didnt get much help on rangerovers.net then.. Rolling Eyes ...maybe it'll get solved here.
Post #47059 23rd Jan 2011 10:18am
HARDRANGE ANDY
Yes, nothing is coming out of any of the returns at all. I pulled all the little pipes off and ran them into a bucket, then cranked it over. The only preasure anywhere around there seems to be coming BACK from the final return pipe just after the front injector, where ever that goes to (somewhere under the inlet manifold towards the mechanical fuel pump.
I think there are 3 pumps, one in the tank, (replaced about 100,000kms ago) one below the cover under the tank (brand new genuine) and one on the engine driven off the timing chain.
I cracked No. 1 injector and there is preasure there, but not as much as i would expect from an injector line. unfortunatly the fittig on the front of the rail is in a bad position and i cant get my gauge on there to test line preasure.
No. I think if the td6 was released in usa they would be a bit more help. I only found this forum through a link archived on the AULRO.
Andy hardrange.com
Post #47073 23rd Jan 2011 11:58am
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
try looking for info on a e39 bmw 530d or an e53 x5 3.0d they are the same engines as td6 2002 td6 vogue, 06 supercharged facelift
Post #47074 23rd Jan 2011 12:01pm
HARDRANGE ANDY
Thanks, I was wondering which bmw would share the injectors while i was looking earlier. hardrange.com
Post #47096 23rd Jan 2011 2:10pm
elpeede
Ok sound like an injector pump issue then. I can't recall where the sensor is that shows you with 3 bar.. maybe the blockage is further down the line. 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #47152 23rd Jan 2011 6:40pm
HARDRANGE ANDY
I think its the one in the top of the fuel filter.
I am going away for a few weeks so i will update on the problem/fix when i return.
Andy hardrange.com
Post #47208 24th Jan 2011 8:50am
HARDRANGE ANDY
IT RUNS...
after changing the fuel fillter, and crank case filter (in the top of the rocker cover) It still wouldnt start, so i stripped the inlet manifold off and had a looksee. I sort-of understand how it works, now. I re-assembled it and tried cranking with atomised wd40 sprayed into the inlet manifold (before i was spraying into the MAF), which still didnt work. Tried again with a petrol rag, and it fired and started. It ran rough, blew some white smoke, then settled down. I let it get warm to bleed all the air out of the system and it starts and idles well.
It doesnt idle as smooth as it should though, and i think it may still have a dickey injector or 2. I unplugged 1 at a time (if you unplug 2 the computer goes into fault) and there was hardly anything noticable when you unplugged #1 or #5. I will be doing more checks today aswell as swapping the injectors around.
Andy hardrange.com
Post #49648 10th Feb 2011 10:16pm
elpeede
Try the leak off teast again to be sure.. then consider swapping injectors about, and again try the leak off test. Also check the injector harness.. there must be a big plug on it somewhere I guess.
Good news that it runs mind Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Post #49660 10th Feb 2011 11:58pm
JIMMYM
Injector wiring harnesses are prone to breaking down with engine heat as well. Maybe you can unhook and do a continuity test on? Part of the harness failed on my 05 TD6 and went down onto 4 pots leaving me stranded 100 miles from home. Anyway what I thought might be a big bill turned into an hour at indies and a new harness piece - £95 all told.
Post #49705 11th Feb 2011 1:26pm
HARDRANGE ANDY
I had a test light on the injectors today, all were fine. I could hear them clicking too.
Andy
I am yet to do the return hose with the engine running. hardrange.com
Post #49709 11th Feb 2011 1:38pm
