Home > Maintenance & Mods (L322) > 2009 4.4 v8 38k miles - what should I have serviced or looke
Flipster103
United States 2009 Range Rover HSE 4.4 V8 Santorini Black
Hi all. I currently own a 2009 Range Rover hse with 38,000 miles. It’s going in for service on the 30th, and I was wondering what services I should request to have done, and what things I should have looked at. I’m a huge believer in preventative maintanece and I wants to get input on here.
So far I’m having the front left wheel bearing replaced, as well as the serpentine belt because it is whining. Any other things I should have done or looked at?
Thanks!
Post #496454 23rd Nov 2018 9:10pm
probably worth getting the front and rear diff oils, and transfer box oil changed.
At 38k, but 10 years, it may be worth getting the gearbox oil changed, the 6 speed benefits from a good oil change and will improve changes, make sure the right fluid is used though as its quite a narrow spec. ZF Lifeguard 6.
coolant
brake fluid
check all the rubbers, bushes and ball joints. There is nothing that can't be fixed with a hammer😜😜
Post #496458 23rd Nov 2018 9:56pm
Flipster103
Just wanted to reply to this as something very unfortunate happened tonight Sad. I was pulling into my spot where I live and I got the "check coolant level" bong and then moments later my engine was smoking and a giant pile or orange coolant was all over the ground. The car was towed to my local mechanic and I'm just hoping it isn't anything major. What could cause this? It was running perfectly fine right before this happens.
Post #496536 25th Nov 2018 7:15am
GGDR
What is a 4.4 2009?
It's not the TDV8 is it? They didn't go to the US.
Is it a BMW unit, only I thought they finished earlier than that?
(Sorry Flipster103, I can't help with your query)
. Cheers, Greg
Post #496539 25th Nov 2018 7:59am
Flipster103
It is the Jag motor (06-09 4.4 NA VCool. Very common here in the USA
Post #496576 25th Nov 2018 12:09pm
