Home > Maintenance & Mods (L322) > Handbrake springs
mercs600
England 2002 Range Rover Vogue Td6 Java Black
Handbrake springs
Anyone got any tips on how to refit the top and bottom return springs ? Tried for half an hour with the top one whilst fitting new shoes and ended up snapping the spring Shocked Had to order some more from Land Rover for delivery Friday. Had a look in my 101 manuals but no hints or tips on how to easily refit the springs Sad
Post #212267 25th Sep 2013 5:22pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I tried shouting and swearing a lit in front ofvthe neighbours. That seemed make little difference.
Then I used some fine tipped mol grips whick worked.
I then cleaned all the blood off the brake shoes and adjusters. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #212275 25th Sep 2013 6:51pm
Old flat screwdriver with a nic cut out of the blade with a hacksaw?
Post #212277 25th Sep 2013 7:03pm
mercs600
Thanks for the advice but I have tried molegrips and a flat bladed screw driver Sad Also a big bucket of swear words with copius amounts of claret from the spanner rash of the hands Big Cry
Post #212284 25th Sep 2013 7:34pm
paneldamage
I don't remember struggling with mine.... I seem to recall that I put the springs on while the shoes were outside the slots then used pliers to pull the shoes carefully outwards and onto their seats... Maybe....
Post #212285 25th Sep 2013 7:37pm
Springs go to the inside between the shoe and backplate
Post #212358 25th Sep 2013 11:01pm
mercs600
Thats weird - my springs were on the outside Confused If they went on the inside as per the diagram you wouldn't be able toremoce them to change the shoes Confused
Post #212373 26th Sep 2013 7:12am
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Not looking to revive this old thread , but whilst checking for any gotchas before changing the handbrake shoes on my SC I stumbled across this thread ... so it’s possible someone else will too
Trying to put the top spring in place requires a fair bit of force as you’re also fighting the tension of the handbrake cable pulling the lever back . This and , because the fit onto the cable is pretty shonky anyway , led me to secure the lever mechanism into its closed position with a tie wrap , which kept the cable in place inside the lever piece and meant that refitting the spring was a doddle
I didn’t take any pics ,s but all will be clear if you are attempting this job . Pull cable out to the extent of its travel , hook the lever onto the cable and close so the nipple is pulled into the lever . Then tie wrap tightly closed .. don’t forget to cut it off before fitting the disc
The pic above of the shoes arrangement is actually upside down and back to front .. ..the springs are on the outside of the shoes 4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #496681 26th Nov 2018 4:13pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
Just a thought as I rebuild these brake shoes , I would agree that the springs should be on the outside of the shoes , but the pic shows that I may have them to opposite ends as well. They are quite easy re a video I watched when it comes to stretching the top spring in The bottom one would be my choice . So is the pic upside down as well.
I reckon so ?
Post #545705 1st Mar 2020 7:51pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
The pic above your post dating from 2013 is upside down and probably reversed!
Adjuster goes to the bottom.
Agreed, when positioned correctly they are reasonably easy to install.
Remember to go through the EPB drive cycle when you have finished (also easy). L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #545710 1st Mar 2020 8:32pm
alfapat
Many thanks , reassuring , that’s great , no epb procedure on this one, old fashioned adjust.
Post #545732 1st Mar 2020 11:16pm
RichM63
Even better. Wink
The cable attaches into the hinged part, doubt that you could even get it down to the bottom of the assembly.
see: http://allbrit.de/LR.cfm?SPRACHE=EN for parts schematics. L322 3.6 TDV8 Vogue. 07MY
Post #545752 2nd Mar 2020 8:32am
alfapat
Ah that’s better...“allbrit “!
Post #545771 2nd Mar 2020 12:31pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Have a look at this
Jim
Post #545789 2nd Mar 2020 3:07pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Did mine last weekend in a blizzard - even with all the stars and planets aligning, getting the top spring on still requires a great deal of force.
Just grab the spring with some strong side cutters and keep levering and pulling it until it goes into in the hole. The feeling of relief when it actually goes in is immense Smile
(And then you realise you have to do the other side...)
Post #545803 2nd Mar 2020 5:11pm
