Home > Technical (L322) > 2011 FFRR 4.4 TDV8 Fuel Burning Heater problem
dmhort120374
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Hi all hope.someone can help.
My car has all.of the T91 fittings for the remote control of the FBH. Currently nothing appears to work and when trying to set manually using the screen I can set the timers but I can not select either heat or ventilate.as both selections are darkened out. Do I need to get the system enabled through autologic or the like?
Many thanks
HORTS
Post #495639 15th Nov 2018 2:10pm
JCW
Perhaps the outside temperature is too warm for it to be triggered?
Edit - should still be able to program it, apologies.
Post #495643 15th Nov 2018 2:53pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Can you set the time in timed climate ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #495651 15th Nov 2018 4:59pm
dolph34
Try turning off the ignition, then press the on butron for the radio/sispalu , then select timed climate and the options for heat or vent should be available. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #495652 15th Nov 2018 5:04pm
dmhort120374
Thanks guys all working now!
Horts
Post #495887 18th Nov 2018 2:26pm
Mickt
United Kingdom 2011 Range Rover Vogue 4.4 V8 Java Black
Hi guys reading this post I have same problem with mine ,-the heat or vent are not lit up,ive tried the test on the topic but no joy ,any other things I could try please ?
Post #496757 27th Nov 2018 11:27am
dmhort120374
Hi Mick
You need to program with the engine switched off to select manual heat / vent.
Cheers
Horts
Post #496784 27th Nov 2018 2:50pm
Mickt
Hi mate thanks for prompt reply ill try that next ?
Post #496787 27th Nov 2018 3:11pm
Mickt
Thanks Hort,just tried it sorted dont know how I missed that .
Post #496791 27th Nov 2018 3:31pm
