![]() | Home > Technical (L322) > trim at bottom of tailgate glass |
InVogue Member Since: 03 Nov 2010 Location: Cheshire Posts: 57 ![]() ![]() |
Not sure which bit you mean - inside or outside? |
When you do figure it out, please let me know!
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Me too.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
Think its wedged under the glass so best left alone.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413 ![]() ![]() ![]() |
The newer cars still don't have it. They stopped using it during 08MY. Now they just have a very thin plastic, just to give it a better looking finish.
I tapped mine with a rubber mallet - went right back. It moved out, so it has to move back... |
ogy Member Since: 24 Sep 2010 Location: Yorkshire Posts: 50 ![]() ![]() ![]() |
this trim can be removed. just lever out one end and pull. i removed mine to paint the tailgate then pushed it back in. i put some washing up liquid on it to help it slide back under. |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1584 ![]() ![]() |
Thread resurrected from the grave.
I just found this (from a link on rangerovers.net |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Easy done, I removed mine as soon as i got the car. Tapped mine sideways using a piece of wood to keep the hammer away from the glass. Lots of wd40 or simmilar. Probably could be tapped downward but I was concerned of the glass. Dont replace it, its much better without 2007 TDV8 VSE
Done. It took a bit of persuading but once it started to move, it moved relatively easily. When there was about 200mm protruding, I was able to grip it by hand and pull it out.
Its an upgrade to later spec, move with the times |
LOL!
A complete win for LR, weight saving, money saving and put they price up, Same glass. 2007 TDV8 VSE
