![]() | Home > Technical (L322) > New air spring leak |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 ![]() ![]() ![]() |
The bf changed mine with an Arnott replacement the instructions were incredibly clear and easy to follow. This was on a 2011 TDV8.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2290 ![]() ![]() ![]() |
Yep having the same problem. Started with just replacing the airbag. Bought from aerosus in germany, turned out to be leaking like a basket. They refunded me, but the garagehours were not their problem. Then bought an entire shock and air spring from maxpeed.fr After assembling it on the car, they said there was a very small leak on the top. When I went looking and turned the steeringwheel the system emptied itself and the car fell back on its' bump. Maxspeed did not reply to my mail at first. After second mail from me they came back with all kind of questions to make it as difficult as possible. Well , they wanted proof on video, so I put in on youtube, within 12 hours I had a reply. "If i wanted a replacement" I learned something, I knew allready but was forgotten. Never go for the cheap stuff, now ordered the good quality part, twice as expensive and hope it will do the job. Waiting for the part now. Good luck with your challenge
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Its a delphi air spring from island 4x4 which is supposed to be OEM, but when i tear it down again i will check.
ok so its been a few weeks as no time to strip it back down and check all of the seals.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6421 ![]() ![]() |
You might be lucky with a battery disconnection and steering wheel left to right, but if EAS SUSP INACTIVE and lights off on the dash, then usually diagnostics and code resetting are required. .
maybe it doesn't help much, but we tried it all even with the Delphi software the reset did not work. Hard reset, no use, steeringwheel left right no use, I've ordered a IID tool from Dan. Hope that will work.
IID tool ordered!
