![]() | Home > Maintenance & Mods (L322) > dynamic indicators |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
This one on the bay: https://www.ebay.co.uk/itm/5-Step-Sequenti...:rk:7:pf:0
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
wow, you have been busy....why did LR make these lights so complicated |
makes sense re a new ribbon/cable...
thinking that if the rear light unit does have 8 vertical leds then a 4 step module would be best [2,2,2,2] |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
https://www.ebay.co.uk/itm/2x-45cm-Car-LED...2443650408
Nah John the strip won't work.
Thats my best googling effort for nowt then !!!! 2015 4.4 AB
Stan you're absolutely right it's eight. Missed than from the inside, maybe two under the IC
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3853 ![]() ![]() ![]() |
https://dictionary.cambridge.org/dictionar...n-t-fix-it
You say that Mike but here's a GIF mock up, might get you tempted?
Spen King will be turning in his grave |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
They are a good find John and would work well with the earlier non led lights. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2732 ![]() ![]() |
LEDs use a driver IC so cutting into the strip wont work unless the drivers are next to the LEDs. The LED strips that can be cut have their drivers adjacent to the LEDs using 12V+/- rails down each side.
