Home > Technical (L322) > 07 l322 glovebox questions
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Is the upper glovebox supposed to open by it self when the button is pushed? Mine's only released, and you have to pull/hold it down.
The lower glovebox seem to go too far down, and as far as I can see, there's a plastic tab that's broken, which should probably have stopped it half way. Is this tab replacable, or a molded part of the whole glove box cover?
Is the lower box supposed to come down slowly when button is pressed, or just drop? 2007 L322 3.6 TDV8 Stornoway
Post #497361 2nd Dec 2018 9:19pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
The upper glove box does need holding down and springs back up when released.
The lower does have soft opening as it uses a gear arrangement. Maybe that is broken. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #497367 2nd Dec 2018 9:29pm
