![]() | Home > General (L405) > SV Autobiography |
BigladUK Member Since: 04 Oct 2014 Location: Milton Keynes Posts: 106 ![]() ![]() ![]() |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 928 ![]() ![]() |
Register and login to Topix, with the full VIN number you can access the original spec. / build sheet. |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1502 ![]() ![]() ![]() |
Best way to tell is the SV badge is on the right hand side and the rear lights are clear lens and the seats will be slightly different style and yes log into topix and that will definitely tell you too. If its a genuine SV Autobiography then it should have a leather parcel shelf and leather in the boot area. All of mine have shown on topix as Special Vehicles, also you should see a small sticker in the door shut that says Special Vehicles.
I’ve already got for the Topix report ( as I mentioned in my original post ) which confirms the car as being an Autobiography , if it was an SVA would this be listed on the build sheet ?
Autobiography Member Since: 10 May 2011 Location: UK Posts: 925 ![]() ![]() |
There will be references on Topix. See screenshots attached for mine
OK, thats perfect
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 226 ![]() ![]() ![]() |
Slight Hikack!
Bushy30 Member Since: 03 Jun 2018 Location: Powys Posts: 1099 ![]() ![]() ![]() |
It's there, just hidden in a tab somewhere! -- click a few tabs |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
I had the same thing on my 2007. The vehicle summary section had basic info on the vehicle but the features section was completely blank. |
I would say the vehicle in question is almost certainly just badged as SVA. |
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 57 ![]() ![]() |
In regards to the SV topic - this car that is up for sale does also have the SV Autobiography badge on the right side but no details on "SV" on the build sheet.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1168 ![]() ![]() ![]() |
Probably added by the owner and bought from ebay! |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 ![]() ![]() ![]() |
The car should also have a badge on the door pillar between front and rear compartments.
