![]() | Home > Technical (L322) > cheap ebay struts |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
ok - just got an answer to my question directly from a very helpful chap at bilstien no less!
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
I really wouldn't do this - you are trying to fit safety critical components that aren't designed for your car. |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 ![]() ![]() ![]() |
I don't think many here would recommend fitting the poor quality struts you're looking at on here even if they were for your car, so fitting to vehicles they're not designed for seems to be madness to me. I understand we all like a bargain and doing everything possible ourselves, but I think there's a thin line between that, and trying to maintain what was a £60-70k car on a shoestring |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 ![]() ![]() |
I've actually no idea why you would want to do this if I'm honest.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Guys. before we jump on the 'who did what to whom' bandwagon. Look at all the old classics on coils. P38s etc, May be worth a thought?? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Worth exploring the concept of fitting standard OEM struts and bags (Delphi) to a car with adaptive damping, if it can be done safely (e.g. fooling the ECUs that all is OK). Earlier L322's coped without it ? Still a saving of +£200 per side.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2727 ![]() ![]() |
If you think that a non-energised CVD exhibits similar damping characteristics to a good non-CVD genuine damper then disconnect 1 front electrical connector as a test. I did this and considered that the ride was excessively firm, not at all like non-CVD dampers.
No burst air bag or any obvious fault with the strut. I can't find any threads which include comments from purchasers of ebay struts though there are several where Dunlop struts appear to have been unsatisfactory. The reason that I'm interested is that it would be a cheap and quick way to eliminate my LF strut as the cause of a LF clonk. On both sides at the front I've just had both arms, ball joint, drop links and inner / outer steering parts replaced, as well as upper & lower bushes + toe links and AR bar links at rear. All done at local indy with quality parts I provided to them. There were no clonks when it went in but just a general 'tiredness' of the suspension with undamped oscillations typical of a 100k mile car. The indy can't identify the cause The clonk is apprent when the suspension is temporarily unloaded (pothole) and, had the parts not just been fitted, would most likely be caused by a worn ball joint or drop link. When I got the car back clonking I had a look to see if anything was loose and noticed that they had fitted a new CV nut I'd supplied but not the new strut/hub nuts and bolts. This suggests that in order to gain better access to hammer out the ball joint, they had swung the strut outwards away from the car and I wonder if this could have caused damage to the top bearing in the strut? I realise that the bearing I'm talking about is actually part of the air spring (which may need replacing soon anyway given the car's 100k) but if i fitted one of those china struts temporarily this could identify or eliminate the strut as the cause? maybe best just to fit a new spring to the strut anyway? any comments on that? |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Didn't clunk before Indy worked on it and now it does? Take it back to the Indy! Bish.
"Didn't clunk before Indy worked on it and now it does? Take it back to the Indy!"
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 ![]() ![]() ![]() |
Just to say...my air springs are original, ten years old and on 145k miles and appear ro be fine...original compressor too.. so yours may have plenty of life left in it yet! |
