![]() | Home > Technical (L322) > Dead Range Rover L322 (no medium speed canbus) |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
I'm guessing they've checked the obvious, battery and alternator?
Kevrobbo1961 Member Since: 25 Jul 2018 Location: Staffordshire Posts: 7 ![]() ![]() |
i stuck a new battery on it for them last week Andy at a cost of £198 |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
Hi Kev
Hi Matt,
buck66 Member Since: 28 Feb 2016 Location: Ontario Posts: 5 ![]() ![]() ![]() |
Hi Kev, I experienced a very similar issue with my 2010 RR HSE 5.0L V8 (North American version).
Hi Folks,
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
That is really good of you to post back your solution, so many don’t bother once their vehicle is fixed. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
It's crazy how that unit can cause such a problem. Fair play to you for persevering & reporting the outcome |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
would unplugging the unit allow the rest of the car to work normally...? |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 760 ![]() ![]() ![]() |
Similar problems here! Can’t even get my ignition lights on at the moment! Car has thrown up almost every fault available, hit a huge puddle last week! Whether that has any consequence!
Hi, it`s the least i could do to post the out come,someone might find them selves in a similar situation and could save themselves a fortune,
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49 ![]() ![]() ![]() |
Thanks for the update Kev. U 2011 TDV8 4.4 AB Bournville Brown |
so if the earlier work hadnt been done more than likely it would have been fine unplugging the effected module...?
possibly, the only thing is as soon as you see smart key not found on the dash and you plug it into the laptop you automatically try to retrieve the key program, by doing this you lose all the codes from the smart key because there`s a break somewhere in the medium speed can system, this will then lock down the KVM stopping you from being able to program the key`s to the KVM because it thinks it`s being stolen and leaves you with a dead car,
