Home > Technical (L322) > Rear Wash Wipe
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Rear Wash Wipe
I fitted a new wiper motor today as mine stopped working I noticed that the wash was coming out from behind the wiper and not the jets so I cleaned the jets out but this didn't work just wondering how many others have this problem. It's always been like this since I got the car but never looked at it from the outside before so thought that the jet down the middle of the rear of the screen was normal.
Post #497950 8th Dec 2018 8:10pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Flip the cap up which covers the locating bolt for the wiper arm - it may just be as simple as the cap isn't locked down in place properly or its gummed up inside the cap (which routes the water from the pipe behind the motor into the nozzles) Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #497951 8th Dec 2018 8:25pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The jet is in the cap which snaps down over the arm retaining nut. If its not snapped down correctly it will leak. I think a stupid design as they can split/crack etc. My one failed so I ran a thin drill into the shaft to remove the plastic inset and fitted a BMW Mini rear washer jet which works fine.
https://www.ebay.co.uk/itm/Rear-Windscreen...:rk:1:pf:0 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #497964 9th Dec 2018 12:03am
