![]() | Home > Maintenance & Mods (L322) > Autobox wont upshift |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
Sometimes faults just appear if you've cleared the fault which you said was intermittent and everything is okay then don't worry to much
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 ![]() ![]() ![]() |
Could the XYZ switch cause this problem? |
ChrisJJ Member Since: 31 Aug 2018 Location: Redcar Posts: 39 ![]() ![]() ![]() |
ta for the replies.
My XYZ switch caused an intermittent fault - sometimes whilst driving the car would go into limp home mode - I believe the switch moves with each gear change? |
Didn't know that. Maybe someone can confirm its operation. |
The fault happened again yesterday.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1030 ![]() ![]() |
The inhibitor (or xyz or gear position) switch tells the transmission ECU where the driver has positioned the gear selector lever i.e. P, R, N or D. It doesn’t change signal unless the gear lever is physically moved. The shift cable connects the two.
ok thats a good place to start then and makes sense.
Yes, ‘fraid so. The sensor is part of the transmission’s internal wiring loom, which isn’t cheap (around £180 from Land Rover), so you need to be sure that’s where the problem lies before thinking about replacing it. Have you any way of monitoring the live signal from the sensor through your diagnostics kit to see if it keeps spiking/fluctuating?
Not gotten round to diagnosing yet as it's been christmas and haven't had the time.
