![]() | Home > Maintenance & Mods (L322) > Leaking steel brake lines to the rear fix |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
Always remember to fit the nut (the right way round) before flaring the pipe...
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6425 ![]() ![]() |
Or my way, (did it twice) flare the second end of the pipe then look down at the nut sitting on the bench in front of me |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
Yeah I've been watching different bending and flaring videos and they all remind you about the fittings yet some still forget. That flaring tool seems to be made in Taiwan and sold here in the US under Titan Tools and Eastwood Automotive labels. Seems to be the best design for a dedicated 3/16 in on the vehicle flaring tool.
Just want to confirm that the double flare is the only type of flare needed for this repair. No bubble flares needed for the line to flex hose connections? |
RRV78 Member Since: 15 Sep 2016 Location: Truro Posts: 203 ![]() ![]() ![]() |
Everything is just double flared all around the car! Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Excellent! OK off to Land Rover to get the spring clips and then off to my mechanic. |
Now if your talking about the spring clips on the front pipes between the pipe and flexi you may struggle.
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
The black pipe clips in pic below I re-used then formed the pipes and pressed them into the recess, didn't use the clips as a forming aid felt they would break if I did.
I wanted to replace these but my dealer said there discontinued
Thanks but jobs long done now fortunately I managed to clean mine up and reuse them. Current: 16 my2016 Range Rover l405 4.4 sdv8 Aruba gold & 11 MY2011 RANGE ROVER L322 4.4 TDV8 ZERMATT SILVER
Thanks guys. My dealer has ordered them for me at $9.50 each. I think I am going to cancel that order. They look the same as BMW clips for $.97 each. Thanks for the picture to confirm that. |
BMW part and number. Look familiar?
10/10 |
