Home > Technical (L322) > Range Rover Vogue 2009 TDV8 sticking ignition barrel
diverman62
Scotland 2008 Range Rover Vogue SE TDV8 Buckingham Blue
My 2008 Range Rover Vogue TDV8 has a “sticking “ ignition barrel.
Intermittent fault which is a really pain😩
Sometimes when i put the key into the ignition barrel I do not hear any electrical system noioand key wonot turn to start.
Taken key out and reinserted which sometimes works
Other times i have locked and unlocked vehicle which sometimes works!!
Why is it doing this?
No fault lights at all on dash when it does.
Many Thanks in anticipation
Post #498514 13th Dec 2018 11:19pm
theres a few threads re this, have you done a search?
Post #498545 14th Dec 2018 9:50am
diverman62
I have not searched at all but will have a look thanks.
Post #498581 14th Dec 2018 2:00pm
diverman62
Battery terminals appeared slack but they are not easy to tighten up!!
When I put key in I can hear some electrical click s but nothing.
Try this a few times and key eventually turns 😩
Both keys are the same. Do i re-code the keys or what would you recommend 1st?
Regards
Post #498969 17th Dec 2018 10:50pm
