![]() | Home > General > bit of a curiosity question |
nickt68 Member Since: 05 Nov 2010 Location: Herts Posts: 99 ![]() ![]() |
I’m pedal first too! Does anyone find that you really have to press the pedal quite hard to register with the car that it’s being pressed? Maybe I’m a whimp but have always been surprised at the pressure requires! |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 926 ![]() ![]() |
L322 has a whole different starting system. The button itself mirrors turning a key, hence why you need to hold it rather than a simple press like the more modern vehicles. |
Garnerj Member Since: 07 Aug 2018 Location: Milton keynes Posts: 69 ![]() ![]() ![]() |
Pedal first then button for me |
Ahh now that makes sense... ![]() |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
Definitely take a second longer with the cold weather....
Indeed. The L322 from 10MY is actually a very old electrical architecture dressed up so to speak. |
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Not on mine, press and let go then it fires up when ready. Ian |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Agree with IanV8 even on earlier models with the key you could turn the key then let it go and the engine would crank until it started, I have a Merc that does the same. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 ![]() ![]() ![]() |
Same here, no delay, fires straight up. Current: FF Westminster money pit
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 640 ![]() ![]() ![]() |
No delays on the petrol SC - and only need a short press as it will fire when ready. I've got glow plugs on my tractor tho so know what you guys are going through |
Double post... |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
+1 for press and it starts , no holding in button , it may take a second or 2 on a frost morning |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 92 ![]() ![]() ![]() |
Brake then press for me.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1091 ![]() ![]() ![]() |
Press the floor mounted starter button on an old mini too hard and it would just go through the floor...... |
