![]() | Home > Technical (L322) > new starting non issue (at the moment) |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I had a similar situation on a Galaxy, it relied on a spring to get to the brakes on position and it was sticking, a quick spray of silicon spray sorted it. BMW i3 Electric Car
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
going to have a root around and see if I can see an obvious issue when it stops raining and sleeting......so probably March time...... There is nothing that can't be fixed with a hammer😜😜
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
Are you sure it's not the starter motor or starter button? My 2012 WM needed a new starter motor at about 55,000 miles, I believe the switch itself is known to be problematic too. Only Range Rovers since 1988 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
Suppose that depends if the symbol on the dash is still telling you to press the brake and the button to start. If it is, I don’t think it will be the starter.
Yeah have had the press brake when starting message. Generally works ok, just occasional..... There is nothing that can't be fixed with a hammer😜😜
I was meaning that if that goes away when you press the brake, then the car knows you have pressed the brake so the issue is the switch or starter, if you see what I mean. Only thing is I can’t remember if that goes off normally when you put your foot on the brake. 2011 Range Rover Vogue SE 4.4 TDV8
I see what you mean. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3555 ![]() ![]() ![]() |
If I'm parked up (engine off) for a bit and had my foot resting on the brake, I'll go to start it and it won't fire with normal foot pressure. Then a few milliseconds of minor panic, then with super press on the brake, it'll light up.
