Home > Technical (L405) > how to disable keyless entry.
Post #496367 23rd Nov 2018 12:47pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
very interesting - nice find Stan Thumbs Up
Post #496392 23rd Nov 2018 3:55pm
Neil183
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
I've just tried this several times and it doesn't work on my 2013 Vogue SE V8. Sad
Has anybody else been successful with this process??
Thanks
Post #498778 15th Dec 2018 10:30pm
JCW
Doesn't work on my 2014 either.
Post #498779 15th Dec 2018 10:33pm
Fleagle_UK
over on the disco forum - they use the same procedure and seems to work. However on the RR Sport forum - someone has mentioned for it to work the ignition has to be on when you do the sequence. May be worth a try on the RR.
Post #498780 15th Dec 2018 11:25pm
palli
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Worked on my 2016 AB after a couple of attempts 2008 Vogue Black - gone
2012 Vogue SE White - gone
2016 Autobiography Blue - gone
2019 Autobiography Grey - gone
2020 SVAutobiography Red
Post #498789 16th Dec 2018 6:57am
smartymarti
United Kingdom 2014 Range Rover Vogue SDV8 Corris Grey
You need to be inside car with Driver’s door open no ignition on , worked,on my 63 vogue
Post #498795 16th Dec 2018 8:43am
Kace
Did mine today. Had to be inside the car, with the driver door open.
The headlights flashed three times to acknowledge the setting.
2014 L405
Post #498873 16th Dec 2018 11:34pm
As above.
Worked on mine on second attempt. Door open. There is nothing that can't be fixed with a hammer😜😜
Post #547143 14th Mar 2020 4:39pm
RRD
Belgium 2012 Range Rover Vogue TDV8 Santorini Black
Doesn't seem to work on my MY17. '17 Range Rover 5.0 Supercharged AB (Sold)
'16 Range Rover SDv8 AB (Sold)
'15 Range Rover SDv8 Vogue (Sold)
'13 Range Rover SDv8 Vogue (Sold)
'12 Range Rover TDv8 (Sold)
'10 Range Rover 5.0 Supercharged
'03 BMW E39 M5
'01 BMW E46 M3
Post #547470 17th Mar 2020 8:58pm
Drksde
8 range rover models stolen in the last 14 days in my surrey town ..... just turned off the key less function this worked straight away in my 2016 RR, drivers door open ignition not on and follow the sequence ... the headlights will flash 3 times and the doors no longer respond to touch. Fingers crossed ... also I make sure my drive way gates are closed every night.
Post #584216 17th Feb 2021 10:57pm
supershuttle
Worked fine for me Geoff
Post #584220 17th Feb 2021 11:04pm
slightly off topic but also make sure you superlock the FF by double pressing the lock button on the keyfob, or you can configure 'one press superlock' via the iidtool.. ... - .- -.
Post #584246 18th Feb 2021 9:05am
tomo141
Works on mine - MY13 Thumbs Up ------------------------------------------
L460 D350 73 24 model FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #584511 20th Feb 2021 12:28am
CMJ
2015 Range Rover Autobiography TDV6 Santorini Black
If your keys remain in a faraday pouch are there any other security benefits in disabling the keyless entry ?
Can keyless entry be compromised without the original key being in range ? 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream
Post #584529 20th Feb 2021 10:49am
